RE: CAP or Extra?
Well, after 272 pictures taken, only a handfull made it to the final cut, so without saying too much more, here's the progress,.....I got the pull-pull tubes installed and went on to the horizontal and vertical stab mounting. I must admit, I bought a robart incedence meter years ago, it's been invaulable in many projects, it's the primary tool in setting up stabs and wings. So that part is done along with the turtledeck stringers and the sheeting, added the top block and wiped away the excess glue. I'll let this sit till tomorrow, then I'll shape the top block and continue on motor and servo install if brian doesn't show up to work on the little boat, but we'll see what happens. I got alot done today and moved along to where you are almost, funny how one day and I'm back up to snuff with you. The old saying of "do one thing a day" really keeps you moving, I had to spend the whole day trying to play catch up, but at least I'm close if not tomorrow I'll regain the reigns and push to covering this little gem.
