ORIGINAL: Gryphon
Last year Ihad an idea to make a custom motor that Ithought would be one of the most ideal setups.
The finished motor is a MEGA16/35/1.5 2700KV (measured on 3S) and 2800KVmeasured on 5S.
16/35/1.5 C is a 5mm combat shaft, Imade sure that its wires come out of bottom side when bolted in F-27C motor mount. Iasked for slightly more expensive bearings.
6 Poles.
Resistance was measured to 0.0128 Ohms (2) phase by Moparmyway. Use that for NEU/Castle creations simulators.
Resistance of 0.0064 Ohms for single phase simulators like MOTOCALC.
56.5mm length
155 grams
Options of 3.2mm or 5mm shaft. We bought 5mm shafts.
All (3) of us are very happy with the results.
4S: 2780 KV
Pic below shows the new motor next to 16/25/2 2650KV.
Gryphon,
This thing just lookswicked!!!!
