RE: Hanger 9 Hellcat Post Crash Report
Hey RBean
Go for the big CMPro P-40 Warhawk, or the F6F. Your engine + Retracts will fit in perfectly.
Another suggestion is that in ARF's you should always reienforce the structure around the wheel wels and the retracts, with poxy resins and glasscloth 3/4 - ounce.
Take also ypon consideration that the same would have happened if you would fly the same way witha 1:1 airplane.
Try to avoid power dives unless you are sure that the structure will not fail. (Most of them are stressed havilly like this..!)
Anyway good luck on your next plan.
J.R.
