RCU Forums - View Single Post - Homelite 45 Ignition Help
Old 06-23-2009 | 08:31 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Homelite 45 Ignition Help
The gap should be the space of a business card
get the magnet in line with the coil. Lay the business card there and install the coil against the business card and tighten down.
Remove the card
There should not be any wires attached to the coil except the plug wire going to the plug
You will have to spin the magnet past the coil as fast as you possibly can to see even a weak spark
It is unlikely that you will be able to start the engine by hand
