RE: CAP or Extra?
What type of paint are you using, if it's lustercoat, be very carefull, if it's put on lexan or polycarbonate parts like normal, it will attack it and curl the part. You can use it, but you have to do dusting coats, The best place to apply the paint is on the inside of the canopy, the outside will protect the paint and is will always be smooth and glossy. Just like a R/C car body. Just mask off your tint on the inside, and spray a few light mist coats inside the canopy, check for opaqueness after each coat, when it's a solid color, your done. You don't need to scuff the surface or anything, when done glue the canopy down with the formula 560 canopy glue or screw it in the corners into the 1/4x1/4 side rails.
