RE: Kyosho Jet Stream 800
The EVX and Titans should work fine-EVX has thermal shutdown if things get too hot.The EVX2 should also be waterproof like the one I use.I agree with using Deans connectors-I use them on all my models.Just make sure gear mesh is correct and grease the shaft so there is no binding.
