RE: Kyosho Jet Stream 800
If you still have the stock prop try it and see what speed you get and how hot the motors get.The Titans have more torque so you may be able to go with a slightly larger prop.With a dual motor and gear reduction you might be able to go as big as a 50mm prop like some of the Robbe and Graupner boats used to use[hydroplane and systems cat].
