RE: HBX, Who else owns one??
I use the Bonzer for bashing, mainly offroad but some onroad, it has a 3000KV brushless ezrun motor, medium/hard dampers and now has new HPI MT Mesh wheels with Dirt Hawg II tires, should correct some of the overgearing but my problem is the wheels are a different offset so they almost scrape the knucles and i wanted some clearance and improve the stance.
I had found the extensions but there's a problem, when you add something to widen the stance and distance the wheel from the knucle you loose thread to screw the nut that secures the wheel, and i'm at the limit, that is why i wanted to find something with more thread, that way i could try wheel extensions...
