RE: Rpm problems...
Antony
Had this problem long time ago with my kj66. a) change the position of your rpm sensor b) try to separate all the wires of your rpm sensor if you have them together with egt sensor and do not mix them with any of the starter, ground or glow wires just keep the rpm sensor wires by its self . and try again it should work fine.
Eftychios
