RE: X dogbones with XL cups?
Why doesn't it work? They seem to slip together perfectly. The bone doesnt sit out, I realise that but they should hold up for a little while. Its not perfect but it will definitely will work. The only play is that the ball is 2mm smaller, once some o-rings/fuel line is behind the balls they should be ok.
I will just run them until they give way.
