Old 07-17-2009, 11:17 PM
rbg
Default RE: Internal setup for AMA 424 racer
Been doing this for years. Put your servos behind the trailing edge. That means 3 servos and a switch. THe string is for vibration. If you use a pc of wire to turn switch on it could cause other big issues.
Trael on all is Elevator 5/32 up 3/32 down. Aileron up 7/32 down 5/32. Rudder as much as you like. 1/4 inch is usually used.
Make sure you go to nmpra websitte so that motor is set up right to shut off on command. We can tell you how in an other thread.
