RE: Any kit cutters cutting Duellist Mk.II from M.A.N plans?
The way the ribs are "stacked" on the plans is kinda goofy and on the odd side the lines kinda cross and don't quite line up around rib 3. I was still able to cut sets for the two MK IIs I have built. If you run a little wide when cutting rib 3 you can clean it up with some sand paper and all is good.
