RE: Rustoleum Universal Paint
Showtime,
I don't think you can get Rustoleum custom mixed. For a custom color you can use latex or use Nelson's paint which has a cub yellow. Nelson's does not come in spray cans, so you can brush it on. I use a lot of Nelson's and it will flow very well. The best way to apply it is with a small foam roller. It takes about 6 coats, but the paint goes a long way and you will use a lot less than you think. It's good paint and I highly recommend it. Butyrate dope is also a good brush on paint. Both are fuel proof without a clear coat. Latex will require a clear coat of fuel proof paint.
pmw
