RE: MOKI RADIAL Care and Maintenence
Hello,
This forum is very interesting , at the beginning the RCS 215 was difficult to start, lot of deadstick with the Waco33%, we change the 6 volts batterie for a 4.8 volts, after fire miss lot of time, until we found the problem came from the ignition connector, the mall connector was not tight enough, we unscrew the black cylinder ignition, open it and solder the wires directly, since that time it run perfectly with synthetic oil, like the RCS 250 ,
I will suggest this forum in our website .
We are in the process to manufacture a scale kit for the RCS150cc.
Thanks all for the very good informations.
Michel
