RCU Forums - View Single Post - DL 50 low compressions, low power, bad idle
Old 07-26-2009, 12:42 AM
Tired Old Man
Default RE: DL 50 low compressions, low power, bad idle
If it's stuck the ring will likely only be stuck on the exhaust side of the piston. So half will be flush with the side of the piston while the other side will be sticking out the side of the piston. The rpm you describe sounds more like a timing issue. Worth checking and easy to do. Check www.ch-ignitions.com for a timing protractor and instructions.
