RE: New JetJoe J-Junior 4lbs turbine
Thank you for the info Smithy.
The engine run beautiful , but when it stops the sound then ,i dont like it., but like you say it good be the camera
How many hours did you test it in very hot conditions ?
Wow 30 to 35N , i have the 40rs engine , and its only a bit bigger 62MM , it produce 2.7 kg now , but i dont use 30N or more , it only needs 15N , and thats how i run with it for almost 70 hours.
full trottle about 40 hours .
I just want to test it , because when the 4 engine coming on one tractor , it has to be good , with no problem.
But ok ,if you say that it realy needs the 30 to 35N i believe you .
Good luck with it.
Best regards,
Martin.
