RE: How do you program a delta wing for futaba?
Pete
The great thing about radios like the 12FG there is often different ways of settings things up. We have the Futaba flying wing set up that allocates channels 4 and 5 to the elevons. To operate the canard servo I allocated it to channel 2. I then mixed it with the elevator and had to put in 50% rates to get the right amount of reduced movement. Also the sense of the servo needs checking to make sure it is moving the right way. There are no flaps on the FEJ 1:9 scale so that is not an issue.
John
