RE: TBM 93
Ohhh , i forgot to mention..... the suggested tail wheel servos are too weak if used with a solid direct linkage. I broke 2 servo, one Hitec hs65 and one HD-2213. The HD2213 was performing much better but after 3 flight some internal gears were broken.
I would suggest to install springs on both side of servo output to link to the wheel. Or do like CHAWKJIM and use nylon rod to connect the wheel lever to the rudder servo.
Daniel
