RE: SM MIG-29 Maiden
Hi guys
I had the same problems:
1º - the aluminum actuating arm for the left and right side elevator hits the side of my pipe - TRY TO TURN A LITTLE THE ARM
2º - pipe touches the fuselage. USE CERAMIC BLANKET FROM BVM.
3º - gear doors toutch in tanks - USE DREMEL TO INCREASE THE WOOD WALL AND USE EPOXY TO FIX THE TANK
4º - cockpit should be longer - USE BLACK PLATE TO ADD TO THE FRONT OF COCKPIT
5º - is not possible to center the tail pipe cause if you center can´t fix to the OVT - I HOPE THAT HAD NO PROBLEM IN FLIGHT!
6º - the servos recomended can not be used in the wings - PUT THIN SERVOS
I had no problems with tank and balancing!
EVERY PROBLEMS ARE EASY SOLVED AND IT´S GREAT PLANE!
João Matos
