RE: Internal setup for AMA 424 racer
If you use the plastic celvis from dubro on your engine or the plastic ball cup for the nelson, you wont have any vibration back to the servo. I have used wire that is a little smaller then 2/56 and the cable from dubro and either seem to work just fine.
