RCU Forums - View Single Post - GP Eagle 580 (Matt Champan cap 232) 50"
Old 08-07-2009, 12:00 PM
raflyer
My Feedback: (14)
Default RE: GP Eagle 580 (Matt Champan cap 232) 50
I have the 580 as well, i have fixed my gear 3 times so far! Here is what i did to eliminate the problem. I cut a new 1/8" lite ply piece to go between the 2 formers in place over the stock gear blk. Then i added 1/8" balsa SQ's onto the fuse sides from the firewall back to the 2nd former. NO more landing gear issues!! I need to play with the CG now and also, with a cheap 42-50-800Kv motor and a 3800mah 14.8V batt, i don't have enough pwr to pull out of a torque roll! I am running a 12x8 so im going to switch to a 13x6 and see what happens. Was only getting 525W and 30amp draw Advice? Thoughts?
