RE: Maybe a silly question: side thrust - why we need it ?
Engines are usually mounted with a few degrees of right and down thrust. The right thrust aids in directional stability. For example, insufficient right thrust will manifest itself when pulling vertical as the model will want to yaw left. This is due to a number of phenomenon including asymmetric propeller loading.
