RE: want to use landing gear switch to activate and deactivate servos
I don't know about FASST systems, but I think a DX7 would be able to use one mix to negate the function of one control, and a second mix to invoke the use of another, both mixes operated from the same switch. So you would if effect turn off one thing and turn on another with a single switch. Is that what you had in mind?
