RE: Battery Problem
The problem im seeing is that 1 battery is too small to power such a hull and that motor is far to small to power a 32" cat.
You need to pump up to a 540-580 sized motor and you also need to jump up to a pair of 3s packs or 2s packs depending on your set up.
