RE: 2.4 ghz Jammers
I have purchased one of these devices to check if it will really jam the RC 2.4Ghz systems and I am sad to say it will. This thig will knock out your system causing it to go into fail safe when you are at equal distance from the aircraft, when the distance is greater from the transmitter you completely loose control. It worked on every 2.4Ghz, Spread Spectrum system out, even Futaba's hopping one because it covers every channel there is, nothing will work. There are serveral models, the one that works the best is the one that is for Bluetooth / Wifi. This thing is palm size, will fit into your pocket and you would never know it is there, you would have to search everybody that came close to your flying field and with a few mods you can increase the range of this thing to a easy 1 to 12 miles depending on how much the person wants to spend.
