RE: 32' cat twin powered
well it all depends on how fast you want to go..
twin 6XL is alot on 4s, possibly to much for the hull to stay on the water
I would pick a lower kv motor say around 1800-2000kv if your going 4s, also run times will be longer
also weight will help keep the boat stable, so don't worry much about adding to much weight
