RE: Truggy front tires ballooning. HELP!
Pick your truck up off the ground and tap the throttle. Do the tires ballon? If so, they may ballon with a thicker center oil. True the tires won't be rotating as fast when on the ground but you get the idea.
If you're worried about performance, I'd worry more about overall handling than tires balloning. Just changing the center oil weight will change the handling along with tire ballon. If there is some aspect of the handling you don't like, fix that first. Read up on what diff oil does to handling, then make your own informed decision:
[link]http://www.rc411.com/pages/howto.php?howto=24[/link]
