ORIGINAL: Eganwp
Basically just looking for a good setup on a budget. I'd rather not spend $400 on Smart Fly equipment if I can help it... :P
Thanks!
As stated, don't worry about the smart-fly. You could also use two Nicads into 2 seperate switches plugged into the Rx - one into the battery port, and the other plugged into a Y lead into the throttle (or where ever). If you use Lipo's you will need a regulator. A seperate remote kill switch is also a good idea, this could either be an optical style kill swith plugged into the gear channel or a seperate servo to control the choke. Either way works.
