RE: cutting out of tail servos
Yeah, BigTim.. I forgot to mention that, so thanks for doing so. I always hit a drop into each hole. I put the screw through to establish a thread then hit it with CA and blow into the hole to make sure it doesn't set up into a glob but gets into the threads, then let it set up for a while. Then I carefully chase the screws through and set them in snugly. It's always worked fine for me and I too have never had a problem with that. Often, the CA may be somewhat "wet" in places which really sets up with the servo screw and forms a bond which will come apart, but is tight and secure.
A good reminder for sure, and a good practice.
CGr.
