RCU Forums - View Single Post - Receiver for combat?
Old 08-28-2009 | 06:08 PM
Alex Treneff's Avatar
Alex Treneff
Default RE: Receiver for combat?
ORIGINAL: Bad Tooth
Can anyone suggest a good, cheap receiver to use for combat? Is there any problem with using a single channel Rx with a plane like the battle axe?
We have been using the Assan X8 2.4Ghz system here for a while and are pleased to announce that TreneffRC is now an authorized USA retailer for Assan.
The X8 system is great for combat because it is small, light, extremely affordable, and of course with 2.4 Ghz there aren't any interference issues to worry about.
The X8 system, which is great for your whole fleet, allows you to turn almost any existing 72 Mhz radio with a module into a 2.4 Ghz broadcast system in 60 seconds. Simply pull the old module from the radio and snap in the new Spread Spectrum module. And of course you still have all your current programming in the radio.
I really like the system because I can go to an event anywhere or be at the field on a busy weekend and not have to worry about being "shot down" by accident as I might on 72mhz.
[link=http://treneffrc.com/proddetail.asp?prod=078999100889]Assan CF-I combo for Futaba/Hitec[/link]
[link=http://treneffrc.com/proddetail.asp?prod=078999100896]Assan CJ-I combo for JR[/link]
