RE: All things TXT-1
Ok, the throttle thing seemed to work itself out, not sure what the problem was.
Using Hobbico cs-70mg super torque 2bb servos front and rear. Did some adjusting on the servos and found one of them was slipping so I ended up gluing it, couldn't get it to stay put. Ended up also moving the front servo to the rear, seems like it has no power, moved it to the rear and that helped but I think it's not working as well as the other.
What's a good replacement?
Also, how much difference would more powerful battery make on torque? Don't care about speed, just want power. It just has the stock motors.
So far it looks like a good rig. Mostly just having trouble with the servos and steering setup but I think I'm close.
