RE: All things TXT-1
Here`s mine from a couple of years back,
I put an e-savage 14.4v esc in it and also a pair of e-savage 20t pinions,
there about as large a pinion as you can fit on the txt, but with the twin 4200 battery packs
they are great for a little bit of climbing and also give the txt a good top speed,
i also recommend fitting a ful set of ballbearings as the stock bushings do hold the truck back some
and its alot smoother running with the bearings fitted,
i have fitted kyosho usa1 tires on the stock txt rims and got a new clod body fitted with parma decals,
also have 4ws with 2x 15kg steering servos fitted, not the strongest servos but they do the job
