RE: Sebart Miss Wind S 50E
Arnaldo ... am unsure about the spinner size, I think its a 2.25", doubt its 2.5" ... I shall measure it for you tonight. As for my set up is as follows:
Motor - DualSky 4260-6 (566KV), not recommended, it is being pushed too hard, I will be using my Hyperion 4025-12 when it repaired
ESC - Turnigy 80A
Batt - Rhino 20C 5S 4,900
Prop - APC 15x8E (soon to be XOAR 16x10 or 16x12)
Servo - HS65 (AIL), HS5485 (ELE/RUD)
Using the Hyperion motor I shall need to use spacers as the motor shaft is too long. Maybe I can cut it. Don't need such a long shaft anyways. As for servos the HS 5485s are cheap but good digital servos for 50 sized planes, they center well and are smooth. The HS65s were good, no issues on centering or blow back. Using HS5065s would be nicer I guess, why not? We should spoil ourselves.
