RE: Byron 51 Build Thread
The 40 I worked on had two rings and the piston measured sightly less than 1.500", about 1.490" if memory serves me correct. There were more than 35's made with two rings, you relly do need to measure your bore to be sure. Will try the g38 mag trick to be sure, thanks.
