RE: Checking amp draw on a motor
You really should consider getting a good watt meter. The watt meter goes between your battery and ESC, and will tell you voltage, amperage draw, watts, and milliamps used. It's much more suited for RC use than a standard DVOM.
I use an E-flite watt meter, very high capacity, and was just under $40.00
