RE: Avistar with OS 46FX climbs by itself.
You shouldn't have to shim the motor to add downthrust. You should be able to correct the climb by trimming out the plane using the trims on the radio as well as the clevis on the elevator. Simply adjust it so that the plane will fly level.
Ken</p>
