ORIGINAL: hugger-4641
I have 3 Avistars, one has a Magnum .46 XLS, the others have .40 La's ,and all of them do climb a little as throttle is increased. But none of them climb to the point that I can't trim it back to level flight with the slide adjustments on my radio. I would definitely check your throws and make clevis adjustments before I put shims on the motor.
Thats the plan for today, I will fly it and see if I can just use my trim tabs (as far as the throws go, they were adjusted per manual so they should be fine.)
MM
