Gyro-Nosewheel
Patrick,
You can adjust the centering of the nosewheel independent of the rudders, by using the aux 4 channel. You can also reverse the servo as/if required too.
Use code 15 to set the center, or just turn the aux 4 knob as required to find center. Once the servo has been adjusted to track straight down the runway, only a crosswind will affect the take-off roll. Only a minor correction is required. Once you get the set-up dialed in, you won't have any problems.
David is correct!
Harley Condra
BVM REP
RAM REP
Buy American!!!!!!
