RE: adjusting 62p12 gyro in Blueray
this gyro is very simple. Yes light is solid red in HH mode, and light is off in rate mode!
Connect the 3 pin into rudder channel and then connect the gain wire to the gear channel. Please pay attention to the direction on how you insert the gain plug into the receiver. I've find many customer insert into the wrong direction so the gain wire is not be used so please pay attention to the orientation. In the dx6, make sure you assign the gyro to the gear channel so you can access the gyro menu and set the gain to 75% and this is ideal for HH mode. Any less than 50% is your rate mode.
Andy
