Fred:
Here is the piece you construct from G-10 and 1/2 (size was used only to show placement of the side balsa) square stick to mount just ahead of the rear dump door hinge point. Hot air from the engine exits through the top... Cold air from the belly scoop flows through and out the bottom slot. The actual air slot space should be as tall as permissable to scavage the most air.
