RCU Forums - View Single Post - Tailblade Deflection
Old 09-20-2009 | 02:43 PM
matty_p80
Default RE: Tailblade Deflection
mustang
you need to start from the servo! disconnect the control rod, unscrew the servo horn and centre the servo and replace the horn at 90 deg., then you need to go through all the set up to get the link rod the correct length (varies slightly between models). this way the servo will have equal movement when you move the stick left and right!
lots of more detailed descriptions available on this forum aswell as sites like 'Ron Lund's Heliproz South', 'Helifreaks', etc. but i hope this gets you started!
Matty )<>}}}}}]@>
