RCU Forums - View Single Post - Is it a phenomenon of these little 2-strokes that until well broken in, they will not turn a larger
Thread
09-28-2009, 01:45 AM
6
DarZeelon
RE: Is it a phenomenon of these little 2-strokes that until well broken in, they will not turn a larger
Quote:
ORIGINAL: rsieminski
2.5/20(50/50) MA 10x4 17K
Rick,
Before I comment on the subject, this is a stark warning!
This prop at this RPM can present a mortal danger.
Master Airscrew dictate an RPM limit for their GFN props, as stated [link=http://masterairscrew.com/images/selecting_a_prop.pdf]right here[/link].
For a 10" diameter prop, the limit is 16,500 RPM, which is around 15K static, if you allow for unloading in flight.
A blade flying off can take out an eye, destroy your model and can do nothing positive...
As to the subject; I can tell you that MVVS ABC engines would typically gain substantially in top-end RPM, from the time break-in is 'declared' completed...
Over the first 4-10 hours of use (less for smaller engines and more for larger ones), the engine will typically gain 400-1,000 RPM on top.
I guess what allows this top-end gain, would also have an effect on the engine's ability to spin larger props, without straining itself excessively...
Reply
Like
DarZeelon
View Public Profile
Send a private message to DarZeelon
Visit DarZeelon's homepage!
Find More Posts by DarZeelon
View iTrader Profile
