RE: HPI 26 CC bearings
when the bearing starts to go it has side to side play
My T has started and you can tell by the way it's running.
So I think over the winter I am going to tear it down and put some good bearings in it like mentioned earlier and see if that is the problem is the cheap bearing and the stock clutch.
Fast Eddy bearings are the way to go right???
