ORIGINAL: cannouu
oh yea. im not so much into performance. as long as i can get it over 50mph. im willing to richen the fuel to make the engine last longer. also wanna do perfect engine break in. Im doing everything to extend the life, like sealing the engine (non-ps), fuel... Oh and what lubrication is good to put on the piston oil ring whenever i rebuild, silicone shock oil? i tried it and it gave me better compression because of the thickness.
I got to agree with Chris on this one you never ever put shock oil in the engine. The engine has no piston rings like a 4 cycle engine in a car. After every run you should put some after run oil in the engine. I personaly like WD40. When you rebuild then a few drops of after run oil for sure. Nothing else in the motor please!
