RE: only runs with glow igniter on?
I have had this problem before. Start it up and start running it around with the igniter go. Take a WOT pass, then quickly come back in and keep the RPM's up without the clutch engaging and you should be able to take the igniter off. Youu might also want to lean the LSN 1/8 of a turn.
