RCU Forums - View Single Post - RASA Prop Sizing for Neu Motor
Old 10-14-2009, 12:07 AM
Hans Meij
Default RE: RASA Prop Sizing for Neu Motor
Problem with the rasa (folding)prop is that you can not deduct the load from its size. The MAG 6, 21*16 is narrowbladed, the MAG 5, 20*16 is wider bladed and probably a heavier load than the 21*16. The MAG 1 21*15,5 is also a heavier load, a wider blade than the MAG 6 and the blade goes more to the hub than the MAG 5 and 6
