The tailwheel is pretty standard, and is attached with three wood screws into a hard ply plate located in the lower, aft fuselage,,,,,right where it should be. Everything is pre drilled. I did 'harden' the holes with some thin CA.
Don't worry about the wood screws,, they are plenty strong.
