RE: 30% nitro in a RCV120SP???
the carb should be set up to idle with a 1/16'' opening gap in the carb barrel. put a 1/16 drill bit into the carb opening and set the servo to idle at this setting. now you can adjust the low idle screw to find the sweet spot with good transition.
