RE: eagle 50 helicopter
replacing the main shaft is very easy. Remove all the head and linkage above the frame and leaving just the main shaft. Loose up the lock screw on the gear and the shaft will slide right out. If you main shaft is bent then you need a bit of force to remove it.
Andy
