RE: Losi 1/18 mini desert buggy
That looks cute. I guess I've been asleep at the wheel as far as Losi 1/18 products.
1) Is the body pan same lenght as the DT? There's pros and cons for both the Mini T wheel base and the DT but my preference is the DT wheel base
2) What's the problem with battery access? I have a mini baja and I can make/break the battery connection easily without removing the body. And I've upgraded to Deans as well. Access from below looks poor; but there is access via the open windows. If you have girly fingers!
3) Taking the clips off is a bit fiddly but once you get used to it or remember to carry a mini long-nose pliers its not too bad. For that matter, I couldn't really tell from the fotos where the pins are or what type they are.
regards
